Hi, please, is it necessary to remove AC compressor at first to access intake turbo flange (2 bolts) and then there is a way to remove oil check stick pipe (+ access to recirc valve (3 bolts)). Otherwise it's no way how to do it.... Thanks for any hints "how to" .
22291
if you need extra room, you can unbolt the a/c pump, from its bracket, and let it sit out the way a bit.
the dipstick is attached to the turbo's oil drain return line, underneath, as pictured here :
looks like you need to disconnect the oil line from the pipe, and then you should be able to pull it out.
22295
the blow off valve, is attached to the left side of the turbo, and held on with 3 bolts, as pictured here :
22296
hope that helps
Thanks. I am going to try loosen the A/C pump bolts and see if there will be a room to put oil dipstick away....
