so i have a zafira gsi, i bought it 5 years ago with a blown engine, i managed to find a leh engine for £600 from a astra h vxr, the swap was painless as its really the same engine without the balance shafts with oil squirters and forged pistons
the 53plate zafira is showing its age now with a bit of rust and no longer need a 7 seater so its time for it to go
i managed to find a 08 astra h 1.4 sxi spares or repair. cylinder 1 has 0 compression
i really need help with the best way to wire up the leh in there
will i need to use my zaf ecu and loom or can i use the ecu for the astra and remap it
i'm confident with everything else with the swap
any advice would be a great help
many thx
You would really need an ECU to suit the LEH engine. There are modules in the MK 5 Astra that won't work with the Zafira ECU and your 1.4 ECU wont work with a boosted engine.
i was thinking i might need wiring and ecu from an astra leh
i do have a ecu for the leh that came with the engine but didnt come with the key transponder is there an ez way round this
many thanks in advance
