1 - 20 of 22 Posts
G
corsa - think so matey...
wires - yes - have the "blue sensor loom" but not the black loom (not needed as its in your car already)
switches - its activated via the stalks - not got them...
WYSIWYG
They also go well in Astra GTEs
G
Discussion Starter · #12 ·
You will have to ask a proper AStra GSi owner for the full spec - but once up and running properly... it tells you
Time
MPG
Fuel left in tank - in miles
Sensors for
coolant level
brake pads
rear lights
head lights
brake lights
Just need sensors on all the relevant parts to get it working!
Micky! damn man! three figures!
It will also display radio info if you have a vaux stereo.
So i dare say it wont for anybody on here!
You can get adaptors for most decent head units to make it display properly,but they are feckin dear and not worth it.
7:43,feck me you were up early,
You may have pros with the mpg on a corsa,unless you use a gsi engine,as the fuel comp is programed for that engine,dont know if you can reprogram,prob not,you could make everything else work if you fitted all the sensors.
G
Discussion Starter · #20 ·
Free if you were to do it yourself... it just requires sensors and wires wiring up... not a hard job - but it is complicated, and probably lengthy...
Any stereo/ alarm specialists would have it done in hours!
1 - 20 of 22 Posts
