Hello,
For a while i have problem with my bertone z20let. Problem is low boost on low rpm's. I get yellow light on dashboard (car with key). The fault code is p1106. When i am in low rpm, car struggle to accelerate (there is NO trottle, no misfire, nothing, its just not that power i expect from remaped z20let with about 230ps now). Only after about 4000 rpm its start to go crazy as it should. When i delete error code and i drive normal (change gear at about 2000rpm) there is no light on. Soon as i push gas pedal and drive on high rpm's, light goes on.
I change MAP sensor (put Bosch 3bar). I tried with different solenoid on turbo, did not help.
Any ideas?
Any ideas?
