Hi i have an issue with my cluster lights not glowing when i put my lights on.
Ive had all the hulbs changed in the cluster. Ive done basically everything on the forums withing my technical limits as im not mechanic.
I do have all the other system lights working on the speedo/ cluster instrument such as abs, indicators, airbag etc all work fine.
Ive checked all the fuses also and all are fine.
My only conclusion is that i need a new cluster.
Any help would be appriciated.
Are you talking about the instrument back lights when you say cluster lights? If so it could be the adjustable dimmer in the light switch that has failed.
