Hi, I've used OPCOM on my much loved MK4 to try and get the air con working.
I had it regassed last year and they couldn't work out why it was blowing warm, they checked fuses and said it was fine and decided to quote me £400 for a new condenser so I politely declined and used my windows.
But digging out the OPCOM I've now had a read and there's no fault codes, got this information which looks normal to me:
A/C Coding (Air Conditioning)A/C Detected
A/C Information Switch (Air Conditioning)Active 12V
A/C Load Signal (Air Conditioning)Inactive
A/C Pressure4.40 bar
A/C Request (Air Conditioning)Active 0V
Any ideas why it isn't working? Help much appreciated - thanks :)
These have a bad habit of blowing the thermal fuse in the compressor clutch. Put a bulb or meter across the aircon clutch plug and see if it is getting a feed.
Since originally posting this I have:
Fitted brand new condenser and receiver drier
Fitted second hand tested compressor
Had it regassed and it held with no leaks identified
Still blowing warm air...
I pulled the plug out of the sensor and both fans kick in so there's no fault with those.
When I turn on the switch on the dash the compressor only works for about 10 seconds before cutting out - this is a fail safe due to there being no gas in there right?
Can anyone suggest anything I've forgotten to check, cause I'm at a loss as to what to do now
If the system was under pressure, the compressor wouldn't normally start in the first place. If the compressor starts but then cuts out it could be a blockage somewhere causing the system to cut out for over-pressure. Watch the system pressure in Op-Com, see what it does when you first turn the system on before it cuts out.
If the condenser, drier, compressor and clutch are all good as you say I would start investigating inside the car, namely the evaporator and expansion valve.
I would advise you seek assistance from a specialist vehicle ac technician as they will have all the kit and experience to assist you diagnosing your issue. If you are located anywhere near Nottingham I would advise you contact ACDC Air Conditioning as Darryl is a magician when it comes to vehicle ac.
If everything works for you, then why do you need to change something. In extreme cases, you can do a chemical cleaning of the air conditioner and forget about it. If you have any problems again, you will make a complete repair of your air conditioner, it's logical, damn it:) Recently, my air conditioner also stopped working at home, and I thought that I would have to spend a lot of money on repairs. But a friend threw me the current prices for repairs Price for Aircon Service, Chemical Wash, Overhaul & Gas Top Up, and I stopped worrying about my money. It turned out that I just had to do a chemical cleaning of the parts, that's all!
