1 - 11 of 11 Posts
AST1603 Supersports 278 Degrees are the cams I have bought.
I was just wondering how much will it cost roughly to pocket the pistons so that they will accept the extra lift of these cams.
Any help will be greatly appreciated
Cheers lads I took the engine apart and left with an engineering company to polish the crank and skim the head and check if she needs rebored. I will hopefully have the cams in the next couple of days and will get them to machine the pistons if does not cost too much
Oh yes one more thing will she run on her standard management of will have I have to fit a unichip or some sort of piggyback ecu
it will run on stadard set up but then again run is a loose term. It will not be as good as it could be.
Just wondering because it will prob be a month or two till I can afford to put a unichip into her.
Cheers for your quick replies
Discussion Starter #9
Just wondering chip of the top of your head how much would either of those engine management systems cost
1 - 11 of 11 Posts
