Hello,
Some of you you know me from here and other forums. I am writing as alex new. I have a Opel Vectra A'93 facelift (same as Vauxhall Cavalier Mk3) that now I am using for track day use.
It had a c16nz engine, and at 2003 I installed a c20xe engine Ln edition with Bosch Motronic M2.8.
I started to tune the c20xe engine step to step in all sections. The only limits I had was to leave th standard engine managment, the single throttle body design and to have catalysator on the exhaust system. In the last version of my engine it was 2067cc with 87,5mm pistons
The Power results was
220hp and 23,8kgm of torque on TAT Dynamometer
213hp at 7900rpm and 20,95kgm of torque on wheel hubs on Rototest Dyno
Theoritically calculated 230-235hp on Maha Dyno and 215ps/sae on wheel Hubs (Dynapack) (correct multiplier factor =1)
Bellow some older topics with a lot info of the course that had with my engine tuning. I believe will help someones.
http://www.migweb.co.uk/forums/engines-transmission/236518-pics-my-engine-lexmaul-intake-more.html
http://www.migweb.co.uk/forums/engi...-head-flow-capability-anf-high-lift-cams.html
http://www.migweb.co.uk/forums/engi...13-my-new-sbd-type-c-manifold-nikel-pics.html
http://www.migweb.co.uk/forums/engi...ng-results-oversized-valves-c20xe-engine.html
http://www.migweb.co.uk/forums/engi...p-c20xe-without-tbs-photos-custom-intake.html
http://www.migweb.co.uk/forums/othe...ing-quickener-best-solution-steer-faster.html
Some Videos of my car in action from you tube in 2067cc spec.
Accelaration from second gear 70-165km/h
http://www.youtube.com/watch?v=t_-UrxbHiJE
Accelaration from 1st gear 30km/h to 195km/h plus
http://www.youtube.com/watch?v=Gvw7YAYXi2c&feature=related
Race with 1.8 integra crx from 70km/h
http://www.youtube.com/watch?v=Cb8e5hxga9I
After all these modification I 've builted the same engine with a new engine block to a 2.300cc with new pistons and sold the cams to use some new ones with solid lifters. The new engine worked ok for 2100km (with standard c20xe camshaft) and the happened the catastrophic engine failure.
More info for this in the below links:
http://www.migweb.co.uk/forums/engi...-project-c23xe-going-very-very-well-info.html
Video of the engine failure.
Accelaration on 3rd gear up to rev limiter. Then with 4rth gear and we have the results of destruction. The engine was with the standard c20xe camshafts that's why the engine sound is calmer than the c20xe 2067 spec.
http://www.youtube.com/watch?v=sUVjRf3brqc
Here some Pictures of the car:
STAGES OF MY CAR ENGINE
150hp standard
200hp modified with stock internals on engine block - 274 degree camshafts
230hp+ 2067cc forged engine block - 283 degree camshafts
Hello, I am starting to rebuild my c23xe engine.
The current situation of my engine project of rebuilding the c23xe after the engine damage is the below.
Parts I need to find again:
Engine Block 2.2 iron - Ok ( found one from x22se)
Crankshaft 2.2 ecotec -Ok ( I found a xe22se Late type)
Steel Con Rods -ok
One piston Accralite 88mm flat top - Ok
Cometic steel gasket -ok
Arp flywheel bolts – Ok
Repair oil sump and a new oil catch pipe -ok
4 valves for cylinder 1 - Ok
Acl 3-layer main Bearings -ok
A new set of std head bolts for coscast heads -ok
Buy a New oil radiator -ok
Then I will need to overebore the engine block to 88mm using a torque plate, lightening and balancing the crankshaft (remove of balancing gear).
Also I will do some changes this time on the engine and car setup. These changes will be:
Different oil pump (z20leh)
Upgrade fuel pump (Walbro 255)
Dta Management S60
Different wide band sensor ( Zeitronix)
Acl race big end bearings
Crank Vibration Pulley standard (I will remove the aluminum)
The full spec of my new engine setup will be as here:
c20xe distrubutorless DTA S60 Managment
Removed resonator before std c20xe (Vectra A) airbox.
Silicone pipe 90mm diameter fitted in front of airbox to give cold air.
K&N panel filter
76mm pipe from airbox to throttle body
Custom adapter to give smooth air pipe to the strange in shape c20xe throttle body.
c20xe Throttle body overbored to 67mm and shaved pins to give more space area on full throttle. The small butterfly is ovewrbored from 25mm to 28mm.
Custom Intake Manifold (Inlet manifold taper Sbd bolted on custom intake with tapered runners from 43mm to 51mm with hornets inside a plenum of 1700cc capacity. It is 22cm long including the sbd inlet.
Thermal intake end exhaust flanges from ferriday enginering.
c20let yellow injectors 304cc on 3bar (I raised a the fuel pressure regulator to 3,5bar – 3,8 bar) In future Precision injectors 525cc
Walbro 255 Fuel Pump type EXTERNAL
Matching the manifold with the cylinder head.
New Camshafts specs :
Intake: 305 degrees duration, 12,40mm max lift, 270 degrees duration calculated in 1,0mm, 106 degrees full lift, lift at TDC 4,90mm
Exhaust: 285 degrees duration, 12,25mm max lift, 262 degrees duration calculated in 1,0mm, 106 degrees full lift, lift at TDC 4,50mm
Catcams solid lifters
Catcams double valve springs gold series
Catcams aluminum retainers
Kentcams adjustable Verniers
Coscast head (early type 2AH) Ported and polished. The dimension of ports is 49,5mm x 30mm and thru the splitters 26,7mm x 27,5mm.
Coolant mods
The valve seat ported to fit +1mm oversize valves.
Bronze valve guides
Oversize valves Inlet 34mm wasted stem (6mm), Exhaust 30mm (7mm stem).
Accralite Pinstons Flat top 88mm forged with Nippon piston rings
Steel con rods from PPM 148mm
Arp2000 rod bolts
Engine block is x22se from Frontera b.
Removed balancing gears system.
Rebored to 88mm with torque plate, installed with custom internal block girlde.
Skimmed for a squish zone of 1,1mm
Engine capacity is 2300,6cc
The CR eith 94,6 crankshaft and 88mm pistons and skimmed head / block is 12,7:1.
Cometic steel head gasket
Big end bearings ACL RACE 3 layer
Main bearings Acl 3 layer
Crankshaft x22se removed the balancing gear and is knifed edged and balancing
Aluminum Fidanza pot type flywheel 3,5kg - 6 bolts
ARP flywheel bolts
Std crank pulley x22se
Oil pump z20leh with modified oil pick up pipe
Gearbox F20 Standard gears with 4.176CR from D16 gearbox
custom 1st gear 3.33,2nd 1.95,3rd 1.48,4rth 1.13, 5th 0.89
Quaife ATB F20
Quick shift 50% shorter gear travel
Exhaust manifold SBD TYPE C 4-2-1 Primaries diameter 47mm - length (30 inches), Secondaries 54mm, After the collector modified 63.5mm taper to 70mm. In 4rth cylinder I have a EGT sensor.
Racing Cat 70mm diameter with 100 dots per Inch. After the cat the exhaust diameter is 76mm
Magnaflow exhaust muffler 76mm (3") diameter.
Oil radiator (double size from std one).
Pictures
Flow chart of my head
Oil catch tank
Internal block guirlde custom
The new replacement piston
Arp Flywheel Bolts
34/30 Valves from Paul Ivey
Dta S60 and valves again
Quaife ATB
Suspension, Brakes, steering, chassis setup
For the handling setup I am doing some changes from the current setup.
The new setup will be:
Front setup
Koni yellows special edition 8610-1263 SPD50 external adjustment
This part number reduce travel 50mm from the std sport model.
I also upgrade the bound valves with (150Nm stiffer) ones.
Front KW springs for 2.0 16v gsi -40mm height
Anti roll bar 24mm diameter old type design. Polyrethane bushings
Saab wishbones with custum teflon eccentric connection that gives more caster, and Polyrethabe Superflex the rear bushing
Front std top mounts modified to give eccentric alligment to give / reduce caster or camber
Sparco aluminimun strut brace
Rear Setup
Gaz rear shocks Gt6-2294 Rebound-bound external adjustment
Rear springs eibach sportline series -30mm
Rear powerflex bushes
Anti roll bar 20,5mm V6
Camber caster kit plates from Eibach
rear z-speed aluminum strut brace
Wheel Setup
New Wheels Rota Slipstream White 16" X 8" ET34, 7,3kg
Tyres Yokohama Advan AD8 225/45/16
Brakes
Front Brakes Wilwood Dynapro 4 pot with 300 x 25 brake disk from honda s2000
Ebc Yelllow stuff brake pads
Goodridge hoses all around
Rear std 2.0 liter brake disks 260mm
Steering Rack
Power Steering rack from c20let with steering quickener from coleman 1,5:1 ratio. Gives 1,93 turn from lock to lock.
Chassis
Lightening Modifications
Interior
Removing insulation and sound materials and tar -23kg
2 Buckets with aluminium base seats -25kg
Removed Rear seats -13kg
Removed extra wheel 195/60-14 -15kg
Exterior
Modified front Bonnet -4kg
The brakes and other stuff also are lighter like Saab wishbones, New wheels etc.
Reinforcements
Reinforced front subframe with tig and other mods ( Pics in the future)
Reinforced wheel arches
Pictures
The New wheels
Modified std top mounts to eccentrics for more/less caster / camber
You easily you can see the offset hole of 0,6cm
Saab control arm reinforsment with Teflon and ofsset 1,2cm hole for more caster
Superflex Bushes on saab inner control arm
Polyrethane Bushes for front arb to control arm
Koni revalving - reinforced front bound valves
Kw front springs -40mm
Rear camber caster kit plates from Eibach
Front lightweight Buckets
That's for the moment..
150hp standard
Steel Con Rods -ok
Dta Management S60
K&N panel filter
Coolant mods
Bronze valve guides
Arp2000 rod bolts
ARP flywheel bolts
Quaife ATB F20
Pictures
Oil catch tank
Arp Flywheel Bolts
Quaife ATB
Front setup
Rear Setup
Wheel Setup
Brakes
Steering Rack
Chassis
Interior
Exterior
Reinforcements
Pictures
The New wheels
