Hi, I have corsa d 10 plate sxi, my airbag light flashing all the time? Just wondering if anyone know what it is?
Could be lots of things but as Dan said, you need to see exactly what the reported fault is. Check on-line for the error codes and reading proceedure - but if a reset is required you'll need to have it done with the correct tool if disconnecting the battery for a couple of hours doesn't work - many warnings are stored in the ECU and won't go away without a proper reset, some will, so worth trying.
Airbags can cause injury and loss of control if they discharge unexpectedly, so definitely needs to be checked out.
