1 - 12 of 12 Posts
Premium Member
Afternoon gang.
Spend the weekend changing the springs and dampers on the cav i have because i found them a bit to harsh on the car when hitting things like stones in the road or egg-cup sized pot holes, found that the two front dampers were split and the rears seized up, got a new set of springs and dampers which are standard and slapped them on. At the same time the rear passenger side hub bearing was whining so i changed it for a new set, took it for a drive round the block and up and down the small carrageway and it was perfect....leaving the g/f parents house this afternoon, loaded up the car, started going down the carrageway from rushden to northampton when the rear drivers side hub started to rub...bugger i thought...then all of a sudden....bang..the arse was swingging everywere...back of the car was about 2 inches away from the crash barrier and the nose pointing at a flipping big merc undertaking us...at this point pushing gently on the brakes and slowly coasting to the layby was a task...stopped the car got out to have a look...can't see a thing..got back in and started to pull away slowly..banging and grinding...we was only 1/4 from home so on with the hazzard lights and slow drive home...got on the drive..jacked her up and had a good tug on the rear wheel...the whole thing moves about 2 inches in all directions....bugger. now she will have to sit there untill the weekend.
Administrator
kind worrys me, after i was driving with what we think is a knacked front bearing,
glad your ok and glad you didnt crash!
Premium Member
were fine mate...it just shows what damage lowering the car can do if you haven't got the right set-up. The stress on the bearings must build up to a huge amount and now i have took some off i think the bearing just gave up. anyway just going to order a new set for both sides of autovaux..£8 a set... :rolleyes:
Sounds like the bearing was overtightened.
anything more than finger tight the taper bearings overheat and seize up.
Bad news, least you came away unscathed
Premium Member
did finger tight on both sides...one side was done up a bit tight when i took them off and was lacking a bit of grease.
i had this happen on my Mk2 Gte- kids **** themselves, wife was oblivious and i had a stained seat- so know how it feels mate :eek:
You were lucky if the bearings were overtightened. Sometimes the hub snaps and not the bearing, and it is bye bye wheel.......
Premium Member
Discussion Starter #12
it not as bad is me saying to the g/f that i had to use a big screwdriver to free my big end and it took some wiggeling and pushing... :rolleyes:
1 - 12 of 12 Posts
