I have a 6-speed box which is going to be converted to front wheel drive for a astra mk2. Ive had one in the past but all the converting work had already been carried out so Im still a bit in the dark about it.
The problem is that one of the engine mounts is totally diffrent.
the monut that has the gear linkage fits no problems its the one at the front that is diffrent.
So does anybody konw of a mount that will fit?
Also will the astra 16v linkage arm select all 6 gears or does that have to modified?
