Ahhh fook! Just started to wiind my wheel stud in on the pi$$ and buggered the start of the thread in the hub up :mad: Its on a Cav Turbo rear hub
So, what type of thread is it? So i can get it re-tapped. :(
get old screwdriver and carefully scrape out the damaged thread,
can it be fitted on the inside of the hub and screw it outwards , cleaning the damaged thread,
M12 x 1.5mm IIRC
i damaged the thread once trying to undo the driveshaft nut.
running a tap through it sorted it no problem.i think the size mark said is correct,i took a wheel bolt into the shop and we compared them to get the right size tap
