1 - 8 of 8 Posts
can anyone help?
The story so far
Driving along minding my own when out of the blue bonnet connects with windscreen OUCH!!!!
Car gets repaired on insurance but comes back with flashing 4X4 warning light.
vaux dealer decides after 3 weeks i need to change t box
t box sourced and fitted today but 4x4 light still flashing.
temp sender different to mine as 2 wire instead of 1 which i had. Will this effect it ?.
Also could the problem be on the valve block for ATF distribution.
Any suggestions will be greatfuly appreciated
O.K.
Box has different temp. sensor, so have you connected it up or is the wire into the loom unconnected?
If its not connected then ecu will drop system into 2WD.
reply posted
Thanks ill try connecting it up !!
Fingers toes and everything else crossed
Humm.....
1) The flashing 4x4 light. This is normally caused by the wire breaking on the pressure soloniod which rubs against the bulkhead soundproofing.
Can't see how a flashing 4x4 light would be caused by a faulty tx box.
2) Temp sensor. On your 1995 model you will now need to fool the ecu into thinking the tx box temp is ok. This can be done by fitting a 4K1 resistor between chassis and the brown/blue spare wire ontop of the accumulator bracket.
Discussion Starter #6
This all sounds confusing would i be able to use my original temp sender if i had an adaptor made up to the size of the original 1 wire switch.
Sounds like wiring damaged when repairing bonnet (or during incident) and a perfectly good transfer box changed for no good reason.
Ouch!!!!!!!!!!!!!!!!!
1 - 8 of 8 Posts
