1 - 11 of 11 Posts
im getting some 2.0 16v (ATE) callipers soon. i just wondered if its possible to use bigger discs with these by using a spacer? remember seeing it once in total vauxhall and a few years ago in max pooper!
any advice?
Better off redrilling 5 stud discs and using Vectra callipers.
ive seen the kits LMF do, they are 288mm v6 calipers and re-drilled discs, but have heared lots of problems of having a spongy pedal. they are going on a corsa btw.
only reason i wanted bigger discs if for the better looks as ive driven a corsa with 2.0 calipers and the stopping power is ok for me.
fit braided hoses with the V6 upgrade to eliminate the spongy pedal
the pedal on the corsa gsi is poor anyway due to the abs system, didnt want to make it any worse if i could help it!
anyone else had the v6 brakes on their corsa with abs?
1 - 11 of 11 Posts
