On the Astras, they have a relay that powers the ECU and fuel pump, it is located on the nearside shock tower. - (mounted to the coolant bottle).
I very much doubt that it is a ECU problem, I have NEVER had to Change one YET.
Last time I had a Astra that wouldn't go it was two feeds at the ignition amplifier. - the one that is supposed to work the rev counter. (pin 3 i think at the amp). Located next to the Battery, under the coil.
It sounds to me like the ECU isn't powering up, and as the injectors work on a ECU switched earth power should be there all the time.
Hope this helps.
Regards
Marky.
[ 16-07-2001: Message edited by: Vauxweb ]
