Changing the exhaust manifold gasket?
529 views 3 replies 2 participants last post by  muppetman
#1 ·
Hi, how easy is it to change the exhaust manifold gasket on a 2.2L petrol Frontera. And also do you need to change the nuts that hold on the manifold?
Thanks,
Ash
#3 ·
not hard mate, just use flat type sockets to avoid rounding them bloody nuts
id change the nuts if any are a bit rounded as its only pence to buy new ones,
id undo it from the zorst and fit a new o-ring between the manifold and zorst for good measure.
