Anyone know of any garages that are able to properly fit an F28 gearbox to my corsa in staffordshire area please??
cheers
cheers
DIY it with a chris astley kit, piece of cake.
For no nonsense hardcore vauxhall modifying advice: www.VauxSport.com
My Total-Vauxhall Magazine Staff Nova in the www.VauxSport.com garage
My Total-Vauxhall Magazine Staff Calibra in the www.VauxSport.com garage
Just down the A50 there's JNC racing or Jeff Bloor. Noble Motorsports would also be a good choice, but perhaps about an hour away for you.
Originally Posted by wayne451
don't have time etc to do it myself.
So all those places would be able to do it all correctly welding of the G/B mount etc??
You could either take them a kit to bolt in place (which any could do)
Or you could ask them if they'd be happy to fabricate you a mount as required. I'm sure JNC could do that the easiest, if they aren't too stoned.
id probably buy and take them the kit so they could just fit it with rady made parts etc, just umming and arghhing whether to sell the f28 or fit it at the mo, but think id fit it when have spare cash![]()
IF you want mate you could fetch it up to us as im not too far from you. About an hours drive tops to staffordshire.
Chris
No thanks Chris
do you mean making a new mount? that would cost more than buying one from Chris there. then its just a bolt in job. assuming you've done the 2wd conversion/drilled and tapped for the rear mount, the only thing that needs modded/welded is the gear linkage. probably a good idea to make sure whoever you take it to knows the ins and outs or you could find it costing a fair bit.
Chris knows exaclty what to do so having to travel an hour doesnt sound so bad IMO.
rodgerq
no i meant correct positioning of where to weld the mount to etc. How much approx would it cost for the fitment chris? including fitting 2wd conversion and welding linkage etc. Only a guesstimate as i know each job has its own drawbacks which could add to cost etc.
Thanks
on the corsa you dont have to weld the mount on, its a bolt on fitment, unlike the nova - maybe gettin mixed up there?
rodgerq
Yeah sorry lol, confused between the two been reading more nova turbo threads on here than corsa turbo threads where people have fitted the gearbox's etc themselves
fitting of the F28 into a corsa is that usually an engine out jobbie aswell???
I don't see why it should be as they don't have subframes or transfer boxes.
may look into having cambelt done while gearbox is out aswell for peace of mind etc i guess
