wheel spraying
Results 1 to 6 of 6
Thread: wheel spraying
    e99
    e99 is offline
    Feb 2002
    market rasen, lincs
    mk2 astra sri
    wheel spraying
    i have just had a set of alloys shotblasted and am now primering them ready for spraying
    i am using tins of bodyline grey primer but im not sure if it is up to the job do you need a special primer for wheels because of the heat generated or will standard stuff do the job no problem
    if it aint broke, dont fix it !!!!!!
    Mar 2003
    Stamford-ish
    WRX Impreza
    I've just had mine re-done courtesay of the Kwik-fit group, but when I spoke to the professionals, the bloke at the painters quoted that he would use 3 coats of primer and 3 coats of colour before he laquered them. This primer would be more concentrated than your cans so I would double (at least) the number of coats.
    Better still find a mate with a compressor and spray them that way.
    Jun 2002
    Ware, Herts
    Corsa 1.5 TDS 99 bhp
    normal car paint is fine.
    1993 corsa 5 door 1488 cc TD 99 bhp 132 ib/ft torque soon to be a lot more ;)
    e99
    e99 is offline
    Feb 2002
    market rasen, lincs
    mk2 astra sri
    thanx for the advice
    as i have a set of 5 i am using one as a test wheel it has had 6 coats of primer so far im leaving it to harden now before i wet flat it and start on the colour coats
    Jan 2002
    Cumbria
    Disco v8 and a 106D
    Normal paint is fine M8, Just think how hot your bonnet gets on a sunny day.... Reet hot!
    MIGWeb User GSi-R's Avatar
    Feb 2002
    Kuopio, Finland
    Oil burner
    Re: wheel spraying
    i am using tins of bodyline grey primer but im not sure if it is up to the job do you need a special primer for wheels ?
    You should really use an etching primer for the wheels as they are alloy.
    Ben Copeland will give you more details as he's refurbed all his alloys himself.
    Micky
