Corsa b front bumper help
Hey guys, I'm planning on painting the front bumper on my corsa b matt black, just wondering what paint/ primer and preperation needs to be done?? And are they hard to remove?? Been planning this for a while now and just want it done, please help people, thankyou.
Shane xx
Re: Corsa b front bumper help
The front bumper isnt to hard to remove should only take half hour if that. Or you could leave it on and mask the bumper up. You can prep the bumper wet or dry depending on what you prefer.
WET
800 grit wet and dry paper put it into a warm bucket of water leave it to soak for a couple of mins, get yourself a rubber block, wrap the wet and dry around the block and rub the bumper untill all the shine has gone, keep dipping the block in the bucket you want it nice and wet, once you have done it go over it all with a grey scotchbrite you can buy this from most motor factors that sell the paint. Same process rub all the bumper with it get into all the hard to reach parts. then completely dry the bumper off, decrease mask up and away you go
