When the time comes (hopefully not too far off!) I'm wanting to respray my car, I reckon I've got the patience to do it myself but I'll need a few pointers I'd imagine.
My thinking so far is grind back/repair and rusty areas, apply Kurust/the other epic stuff I keep hearing about direct to any bare metal.
Get hold of a good DA sander and sand back the paint using 180 grit pads.
Apply primer, dry and rub back with finer pads than before. Repeat process again.
Make sure everything is spotless and apply paint.
Make sure everything is spotless and apply lacquer.
Do I want to flatten the paint before lacquer with 1500 wet and dry or just do it after the lacquer? I'll be wanting to take the doors/bonnet/boot off and do them separately then reattach after the jobs done.
Colourwise it will be going from flat blue to metallic blue. I want to do the engine bay and doorshuts but I'm not fussed over bits that won't be seen (under the carpets/behind dash/boot floor).
I accept that I might not get it as good as a pro but I want to do it to the best of my ability, granted probably not great!
I'm going to get hold of a good compressor and borrow a nice shiny DeVilbiss spray gun plus build a temporary spray booth to keep the **** out.
Anything else I should know? Not doing right? Etc?
