Preping panels
Results 1 to 6 of 6
Thread: Preping panels
    Aug 2004
    glasgow
    astra 4x4 C20LET TURBO, v
    Preping panels
    Hi, Whats the best way to prep panels for paint, trying to save money on my project, so was thinking of doin the prep work to the inside of my car. What products should i use and how long should i spend doing the prep work??
    Cheers in advance
    Feb 2012
    Horsham, West Sussex
    95 Omega 2.5 V6 manual
    Re: Preping panels
    If theres no damage and it's just to key them up i'd use red scotchbrite and make sure it's nice and matte before painting. Then use a pnel wipe to get rid of any greae, silicone, contaminants etc.
    Feb 2012
    Re: Preping panels
    red scotch bright will be too coarse if you are spraying with a base coat then clear coat as it wnt cover the scracthes from it grey would be best, if painting plastic you would need a 1k plastic primer which would need spraing on b4 you paint.
    Re: Preping panels
    I always use red scotch, what we always used at the bodyshop too.
    Feb 2012
    Re: Preping panels
    id personaly use the grey for base coat and clear coat as will cover they grey scotch marks easier but down to every1s personal preference im just a fussy bugger.
    North Eastern Regional Co-ordinator
    Aug 2007
    washington / gretna
    corsa let, nova xe, mk4 a
    Re: Preping panels
    im with woody, i never use red, bc doesnt cover the scratches properly, there not really noticable once laquered but its not worth the risk.
