corsa c20xe engine bay problem
Results 1 to 9 of 9
Thread: corsa c20xe engine bay problem
    Mar 2011
    birmingham
    corsa
    Angry corsa c20xe engine bay problem
    Hello
    i have a c20xe in a corsa b all running fine etc but was running a eco pipe and adapter so i got a powercap (mantzel one) tryed fitting it and its to big for the gap got told to bang the back of the bay, scuttle bay area so i did with a mate and 1 hour or so later no good frustrated and a dented up back panel later still doesnt fit now ive decided its definately gonna need cutting say a square section now whats the best way to go about this? I was just gonna cut and weld another plate in which wont have the ridges etc in? Or is there somthing that i could do which would look better? As i still want it to look decent
    Is there anything i can do while ive already got the grinder and welder out that the corsa will benifit from? its gonna be a track strip shlag lol
    Any ideas or thoughts welcome
    thanks
    Aug 2009
    bristol
    corsa b arden blue
    Re: corsa c20xe engine bay problem
    I cut out a section and used rubber edgeing strip although idealy you should reroute your brake lines
    Mar 2011
    birmingham
    corsa
    Ok ill try that then thanks
    Dec 2007
    Nuneaton
    A carbed xe'd reno kangoo
    The corsa I bought had been cut and bodged like that with out the pipes re-routed. Not the best idea but worked with the power cap.
    Vectra B Estate 2.2
    Vectra B Saloon 2.6
    Aug 2009
    bristol
    corsa b arden blue
    Quote Originally Posted by Joker View Post
    Its ok as a temp measure but as mine is like it at the moment but i can aimagine the chaufing through the pipe if i was to leave it like that
    Sep 2011
    essex
    Astra sri
    Stop talking about it and get it cut
    INSTALLING SUMMER... ████████░░░░░░░░44% DONE. Installation failed.
    404 error: Season not found.
    Mar 2011
    birmingham
    corsa
    Lol i will i just want to make sure i do it right lol
    Apr 2008
    dublin ireland
    xe/let corsas vectra gsi
    power cap on mine i cut the area under the scuttle and boxed it in about 10mm welded it job done id reccomend rubber edgeing tho as can get smell of exhaust fumes through if in traffic with heaters on edgeing stoppe dthis alot
    Mar 2011
    birmingham
    corsa
    Quote Originally Posted by damoh View Post
    you got a pic mate just so i no?
