4 link suspension
Results 1 to 9 of 9
Thread: 4 link suspension
    Mar 2011
    4 link suspension
    I have a question out of curiosity. Can one built a 4 link setup or ladder bars into a kadett body to change it to rwd as you would in a normal rwd car.
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: 4 link suspension
    if you’re handy enough with a welder and some sheet metal then i see no reason why not, will be a faff around with the fuel tank location etc i would think, but very possible
    SHoNkyOpELs.de
    Mar 2011
    The tank is not a problem as this will be for drags. So the side plates of the body will be strong enough for the 4 link or will I need to weld in additional support like "boxing" the body where the 4 link will be welded in. I don't want to put in too much weight. Also steering wise, will the rwd gearbox fit under the steering or must I modify this to rack and pinion. Don't have trouble re cutting and modifying the tunnel.
    Mar 2011
    [/IMG]
    Something like this maybe.
    Dec 2008
    South West Wales
    Nova Sport
    Have a look at some websites like this, it's my cousins business and work there fabricating shells and parts when I have time (not my full time job). Look at the parts section too, I might give you an idea of what's used and how.
    Meirion Evans - Ford Escort Mk2 Modern Rally Car
    Nova Sport chequered seats WANTED...........
    Mar 2011
    That is great workmanship. I basically know what to do, is just to do that first cut and knowing that there is no going back.
    Northeast Kent
    Quote Originally Posted by gsi racer View Post
    [/IMG]
    thats only two link
    the issue i see is the kadett hangs its rear suspension off the 2mm box chassis rails that run down the outter edges of the shell. the beam is mounted there, the spring platforms are there.
    what you are aiming to do is move the trailing arms inboard to the flimsy floor panel above the fuel tank, below the rear seats. which is ok, but bare minimum it would need to be tied into the outter rails, or roll cage depending what you are doing.
    Banned
    Dec 2011
    Jun 2002
    Wrectum
    Shuvit, e36 track car
    What in the holy f*ck does that mean.
