NEW blisters on OLD paint, help/advice welcome
Results 1 to 22 of 22
Thread: NEW blisters on OLD paint, help/advice welcome
    Northeast Kent
    my car had a full 2k baked respray early in 2008, door shuts, bumpers, everything. the finish was good and had no issues with it
    in the last couple of months the entire roof and upper ends of the A, B and C pillars have started getting thousands of blisters on them, comprehensive even spread over all areas listed.
    any paint experts seen this before and know whats causing it, guessing the only cure is another respray ??
    many thanks
    Jul 2000
    In Gavs shadow...
    Vectra VXR Estate
    Re: NEW blisters on OLD paint, help/advice welcome
    When I've seen this in the past it has been one of two things. One being rust of the metal caused by wet flatting the primer and some of the moisture has gone down through the primer and slowly started to rust. Second cause is solvents being trapped and/or a reaction in the underlying paint layers. But yeah your right stripping back and starting again is the only way to permanently get it sorted.
    Have to say yours is by far the worst I've seen for the sheer amount of little blisters!
    Northeast Kent
    thanks for the info jim
    Sep 2004
    Nottingham M1 J26
    911. Loves: Dirty sluts.
    Can't see why solvents would take 3 years to cause a reaction
    Looks like car AIDS
    Sep 2011
    Audrey the Audi
    To be so uniform and occur at same time, got to be something in the air settled on the paint I think.
    3 years on for several areas to go pop at same time is a bit unlikely?
    MIGClub Member MattJ's Avatar
    Oct 2001
    Kent
    Toyota Celica GT4
    it is really odd, almost the texture of sandpaper when you rub your hand over it
    Dom
    Dom is offline
    MIGClub Member Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    Have you had a look "under" one of the blisters to see whats inside ?
    It looks like someone has sprayed something over the car which has reacted like paint stripper.
    If however you burst a pimple and there is a rust spot underneath then obviously something has got under the paint.
    Have you approached the garage who did it to see if any other customers have had a similar problem from the same age ? Could be a faulty batch of paint.
    Jul 2004
    Southampton
    GTE 16v / Saab 2.0t
    My GTE has done exactly that on the rear 1/4s that were painted 5 years ago.
    Subscribed to thread.
    May 2006
    South Wales
    subaru impreza/mk3 astra
    looks to me as above that either trapped moisture has rusted under the primer or its solvent's rising to the surface (could be that they didnt use a suitable thinner in with the two pack ie standard thinners insted of proper 2k thinners) i work in a bodyshop and have seen stuff like this in the past but not this extreme. only answer to repair this would be to sand it all back and start over.
    Dec 2003
    london
    corsa c20let
    Quote Originally Posted by Jimbo View Post
    I have to agree, who painted it did they give any garanties on the work? tbh you have to go back to bare metail treat it primer paint clear....
    West Midlands Regional Coordinator paddy>gsi/turbo's Avatar
    Nov 2004
    birmingham
    astra mk3
    worst have ever seen. you say car was painted 3 years ago been on road or in storage? car cover?
    its micro blistered theres water trying to find way out.
    damp garage (stored)
    car cover made metal sweat
    Northeast Kent
    thanks all
    it was painted march 2008, kept outside and used daily until summer 2009, then garaged for 2 years. paint was ok when taken out of storgage 2011
    now its done this in the last 3 months, infact it appears to get worse by the week almost like a rash
    MIGWeb Moderator
    Midlands
    Nowt
    Never seen anything so bad.
    Northeast Kent
    just to confuse the investigation its blistering on the wing mirrors and spoiler (i.e non metal parts)
    Jul 2000
    In Gavs shadow...
    Vectra VXR Estate
    Quote Originally Posted by DarrenH View Post
    Well that would suggest water/moisture trapped in the substrate layers. But I suppose it's irrelevent what the cause is it's a full respray to sort it and I doubt very much whoever did it will be much help after 3 years mate.
    Be worth sanding a mirror cover or similar down to see how deep the blisters go. It is bad I've not seen so many blisters and I'm interested to know what the cause is!
    Christ that's a hell of a lot, Solvent pop or trapped water on the primer/paint surface can happen at any time tho. Was the car under cover when off the road? As i've seen that cause the prob as the gasses cant escape.
    Northeast Kent
    it was in a dry airy garage.
    i've been over the car with a fine tooth, there are bubbles on every flat surface (including swage line just below the windows), the roof is the worst like a 40 grade sand paper, however the bonnet and front wings are completely untouched (heat cycles from engine bay perhaps ?) i picked a bubble off the wing mirror and it goes down to the plastic
    Jan 2011
    Looks rather funky!
    If you've picked it off and it does right down then it might well be solvent pop. Sadly it will need repainting.
    MIGClub Member the-darkhorse's Avatar
    May 2009
    poole
    cally turbo td05
    Water in the airline when painted me thinks ! Needs repainting .
    when it was repainted was it done in waterborne or solvent basecoat ????
    HHmm didn't think about water in the air...^ Good point.
    MIGWeb Moderator
    Midlands
    Nowt
    Still took a while to come out really.
