im wanting to prep and smooth the texture out of the bumpers on my nova ready for the paintjob, but seen mixed reviews on how to smooth the texture out. can anyone point me in the right direction on how to do it properly. thanks![]()
you need to 2k prime them.i do bodywork only use lechler ti 2k primer good product.
red scotch.plastic prime.3 coats of 2k primer. rub primer back with 320 grit. then 800 wet flat.
What Paddy said is the best way, same as i did on mine to remove the texture.
what plastic primer would you recommend? halfords stuff any good? im hoping to do as much as i can to keep the costs down. cheers for the advice
you need a compressor and spray gun to get the build with 2k primer.tinni cans are no good.
started a respray today. got a grill to colour code.take some pics of process if you want.
