new to mig welding, good welder tips advice please
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 43
Thread: new to mig welding, good welder tips advice please
    Apr 2010
    southport
    2008 civic diesel
    Hi all, i'm looking in to getting a mig welder, mainly to do little bits but possibly bigger bits if i can get the hang of it, i've done a search and found that a gas welder is better over gasless, and a 150 turbo is a good all rounder, does anyone have any imput to different welders, also any tips that will help me to start welding when i order all the gear?
    Thanks in advance.
    Oct 2004
    Aberdeenshire
    ASTRA SRI 170
    Re: new to mig welding, good welder tips advice please
    Hi mike, you should have a look on this site MIG Welding - The DIY Guide
    I found it very helpful
    Apr 2010
    southport
    2008 civic diesel
    Quote Originally Posted by RAMBIRKETT View Post
    that looks very helpful, i'll have a read of that when i get chance in the next few days.
    Anyone else got any helpful hints for me?
    Dec 2010
    oswestry
    merc vito carrys engines
    gas welders are the way to go as gasless burn alot hotter and will burn through panels ect very easily and yeah a 150 turbo is a good choice!
    as far as welding goes a flash mask (auto darkening) is a MUST as this makes things alot easyer
    setting up your welder is somthing else aswell
    seems a silly thing to say but dont look at the weld to start with listen to the noise its making if its a constant sizzle (like a cooking sausage) then your about right this will need to be changed depending on the thickness of metal your welding
    youwill find your own way of welding you can push or pull your weld (big debate) it doesnt make any difference its just what you feel comfortable with
    theres a few bits quikly probably more but cant think off top of my head at the moment
    hope that helps you out
    MIGClub Member scooby-KILLER's Avatar
    Mar 2008
    unknown
    BADGER spec GSIT WIP
    i bought a mig welder just last month and my biggest problem was setting it up, i way out with feed speed etc, my mate changed that and away i went have had loads of fun using it but as previously said get a DECENT mask, the 1 that comes with the welder i just binned that and closed my eyes, works a treat apart from the burnt face
    MIGWeb Moderator
    Midlands
    Nowt
    Yes, get a good mask.
    Get loads of scrap metal and get some practice in.
    Mar 2008
    unknown
    +1
    its the best way to learn, all tho i never had any scrap metal to practice on i just used my gte lmao
    Apr 2010
    southport
    2008 civic diesel
    some great pointers there chaps, i'll get looking at welders see what sort of price they are and get myself some sheet metal and tubing to practise on. one more quick question after a fair bit of practise would it be a good idea to make my own boost pipe or will i need a load of practise for that?
    Dec 2010
    oswestry
    you can try mate youl no if youve got it wrong
    get a good make secound hand welder dont get a cheap new one
    Apr 2010
    southport
    2008 civic diesel
    i was gonna look at new welders around 200-300 never really been a fan of second had stuff tbh.
    Sep 2011
    Audrey the Audi
    You buy your cars brand new?
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Corsa C20LET/Astra coupe
    On car panels never try and do a continual run as you'll burn through and no doubt warp the panel, the push, pull thing is more relivant on thick stuff to be honest, try to do a series of hot tacks so amps up a bit but a quick 1/2 second squirt then overlap it by half it will prevent burning through as much it's called trigger welding (other names as well)
    Clean panels weld best so remove all paint and rust/dirt from weld area and set the gas to around 15-20LPM or 20-30LPM if outside
    MSG
    MSG is offline
    MIGClub Member MSG's Avatar
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    Oh and like I did, don't risk wearing your vision specs as a temporary goggles to protect your eyes from the intense ultra violet light emitted by the welding sparks, and the flying debri!! I did shut my eyes but then couldn't see eff all so i opened them briefly in between, but the worst thing was my glasses were embedded with tiny flying molten weld beads and stuck to the glasses lenses, and when i scraped them off they also tore off the lense glass (pitted) and now I have ruined my vision glasses that cost me over £100. All because I couldn't be arsed to order proper welding goggles! learns everything first hand through personal experience.
    And then I regretted and had to visit my optician for a new pair of vision glasses, costing me another £100, a few weeks later I was using an angle grinder, didn't think this would cause any serious problems, despite the guard on the grinder, flying hot debri stuck to my glass lenses again ruining them once more!! Learnt another lesson hard way!
    And wear gloves as well, unless you want super tanned hands!
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Always wear long sleeve and welding helmet! Not like them dicks on American chopper and hot rod
    Apr 2010
    southport
    2008 civic diesel
    what are those gas/no gas welders all about, do they need converting to take the gas or is it just optional to connect it or something?
    Dec 2010
    oswestry
    Quote Originally Posted by mikesmith181 View Post
    dont bother even thinking about buying one if your welding panels ect they burn to hot as theres no gas to cool the weld buy a decent secound hand one
    Apr 2010
    southport
    2008 civic diesel
    why do they advertise them as gas/gasless if you cant't use gas in them, thats a bit silly tbh
    Dec 2010
    oswestry
    they have the ability to use gas but you can buy fluxed or standard welding wire thats the difference
    Apr 2010
    southport
    2008 civic diesel
    ah, so in theory these welders are fine as long as i use gas?
    Mar 2003
    Bournemouth
    CavalierTurbo4x4 x2
    Lots of PRactise and get the metal as clean as possible! ****ty metal will give you a poor arc and make it much harder to get a good bead!
    Apr 2010
    southport
    2008 civic diesel
    some great tips here chaps, thanks to all, i've ordered a mask and such, i'm just looking for the welder to go with it now lol.
    MIGClub Member Turbostevo's Avatar
    Jan 2011
    Chesterfield, derbyshire
    Saabastra/E36328/bora/147
    Quote Originally Posted by kread View Post
    ^^^^^ best bit of advice here.
    Apr 2010
    southport
    2008 civic diesel
    Clarke MIG Welder (Turbo) - 151TE - Machine Mart
    This is the welder i've seen, looks about right to me, what do you think?
    Jan 2011
    Tell you what mate scrap the mig welder and buy a tig welde, argon is a bit expensive but tig is so clean, easy and looks better, usually you won't even need a grinder either. Definitely the way forward for anything up to 6mm thick.
  26. #25
    Aug 2008
    Peterborough/ketton
    Corsa
    Quote Originally Posted by Turbostevo View Post
    Ever tried tig welding old crap metal? E.g car body work etc.
    Mig every time for general car work, only use tig when it comes to exhausts and manifold personally.
    Sent from my BlackBerry 9700 using Tapatalk
