cutting pipe with angle grinder
Results 1 to 19 of 19
Thread: cutting pipe with angle grinder
    Aug 2007
    brighton
    C20LET 5dr corsa
    i intend on replacing some of my exhaust! instead of making a whole system like last time!
    thing is i only have a hack saw or angle grinder but how can i get the cuts straight? its so much easier to weld and obviously better fit..
    im cutting 3" stainless pipe
    Roll on LET power....
    Sep 2011
    1993 Astra Mk3 C20NE
    Re: cutting pipe with angle grinder
    wrap a peice of paper round and mark it up - 1mm disk in the grinder
    Aug 2007
    brighton
    C20LET 5dr corsa
    i tried a roll of parcel tape but still didn't cut perfectly straight..will try your method.
    Jun 2002
    Wrectum
    Shuvit, e36 track car
    use a bandsaw lol
    Jun 2010
    aberdeenshire
    escort van :P
    i use a chopsaw. but if doing with grinder, just cut as best u can then try and grind it strate.
    Aug 2007
    brighton
    C20LET 5dr corsa
    i haven't got a band saw or mitre saw etc
    grinder will have to do!! i will just use the method im doing.. its straight enough, plus i can fill slightly bigger gaps with the weld.
    any more ideas or anyone selling a saw let us know
    Jun 2010
    aberdeenshire
    escort van :P
    have you got 9" grinder ? put pipe in vce and you should get a decentish cut.
    Aug 2007
    brighton
    C20LET 5dr corsa
    nah i haven't.
    Sep 2004
    Nottingham M1 J26
    911. Loves: Dirty sluts.
    Don't try and go through with 1 cut.
    Mark a cutting line round the pipe, and cut in a small section, then rotate the pipe and cut along the line again. Then file it back to your actual line you need to be at.
    Aug 2007
    brighton
    C20LET 5dr corsa
    yeah i had a go on a spare bit, took my time doing it in sections so i stayed on the line.
    i think my parcel tape trick will work i just need a longer bit of pipe!
    Oct 2002
    Redruth Cornwall
    cav con
    buy an exhaust cutter, proper tool for the job. or hire one
    or possibly borrow one off a garage.
    youll never get it 100% with just a grinder, but at the same time you cant do it wrong with a proper cutter!
    Nov 2005
    worthing, w/sussex
    Astra "G"
    if you can get to worthing ill borrow the garages exhaust cutter over the weekend
    I smile because I don't know what's going on.
    Aug 2007
    brighton
    C20LET 5dr corsa
    Quote Originally Posted by Astraghoul View Post
    nice offer but i would do it during the week
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Corsa C20LET/Astra coupe
    Stick a jubilee clip on and use it as a guide, put the screw part at the bottom and take your time. Then use a sheet of 40 grit sand paper on a flat worktop and rub the pipe in a circular motion on it and that will take the highs off it giving you a nice flat straight edge to weld with
    MIGClub Member jamied's Avatar
    May 2003
    northampton
    loads of things
    Just use the hack saw.
    Aug 2007
    brighton
    C20LET 5dr corsa
    Quote Originally Posted by jamied View Post
    they any good??
    dewis i will give it a go.
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Quote Originally Posted by dearing5 View Post
    they any good??
    Probably struggle with stainless as I bet them cutters are more aimed at the softer mild steel
    Aug 2007
    brighton
    C20LET 5dr corsa
    i will try your method mate.. might give it a go in a sec.
    ideas on angles? like 30deg 45 etc or a taking the piss? lmao
