Just thought i would stick up some pictures of some lathe work i have been doing recently
on a few throttle bodys
Firstly hears the lathe im using
Uploaded with ImageShack.us
Its a Colchester Triumph 2000 not in bad nick everything works as it should but it looks like its had some abuse over the years.
Anyhow stripped down and mounted up the first throttle body
And an Action Shot
I Managed to turn them out to 70mm much better than the 64mm they started as
now for the butterfly plates first a huge lump of brass turned down to 70mm
And was left with these enough for the ones i was doing and a few extras just incase
Then put them all back together and finally fitted one to my car has made a lot of difference less lag and faster pick up so well worth doing
so far i have done Two C25XE and two X25XE throttle bodies the only small problem with the X25XE type is that after 69mm it broke through into the coolant chamber underneath but as im not using it and a little chemical metal filled and smothed everthing was fine.![]()
