saab turbo corsa(what chassis mod to do)
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 26
Thread: saab turbo corsa(what chassis mod to do)
    Mar 2011
    im putting a saab turbo engine in my w plate corsa wich oready had a 2.0 in it, whilst i have engine out i need to know or to see pics of what chassis leg modifacation i need to do. as i said the engine is out so i need a quick reply here guys, ive googled it and read all the build threads but no pics of a corsa with the chassis leg mod thanks guys
    Moderator Melv's Avatar
    Dec 2006
    KEITH, N.E. SCOTLAND
    1.8 Corsa Merit + ACT
    Re: saab turbo corsa(what chassis mod to do)
    Moved to the technical section for you.
    MIGClub Member bigron1988's Avatar
    Aug 2009
    southport
    570.6bhp corsa @1.9bar
    didnt think the saab engine fitted in the corsa as it was to tall
    carbon clad corsa gsi ,c20let big power build thread
    http://www.migweb.co.uk/forums/proje...lots-pics.html
    May 2005
    central scotland
    astra G coupe c20let
    how does the fuel pump come out the tank?
    Racing is life, anything before or after is just waiting
    Mar 2011
    birmingham
    corsa
    Quote Originally Posted by anniman1 View Post
    bend the little tabs up and hammer it round with a flat head screw driver and then it will just lift out
    MIGClub Member Turbostevo's Avatar
    Jan 2011
    Chesterfield, derbyshire
    Saabastra/E36328/bora/147
    You'll need massive amounts of work to get the engine in. Leave the gearbox mount as it is as then you'll not have to adjust the driveshafts. You'll need a Saab 900 block not a 9000 as thy will give you even more work to do. You'll need to make your own rear mounting point and you'll have to make it really well too. You'll need to use the Saab rear mount with that too. Some major work involved with that 1 mate!
    MIGClub Member scooby-KILLER's Avatar
    Mar 2008
    unknown
    BADGER spec GSIT WIP
    a guy from cupar fife had put a saab engine in a corsa think it was a bit of a pig and not sure what the out come was? al see if i can find any info for you
    Mar 2011
    ive got a 900 engine,im just unaware of how much chassis leg to cut and i cant find picks anywere,i know its not a popular engine for a corsa wich is why i want to do it,i have a mint shell,a great auto spark as a mate and a fabracator so thats why i need some info on how mush to cut,im using my freshly rebuilt f20 so the gearbox shouldnt be a problem, yet!!!!!
    thanks for help guys will post pics as i go along to show any others the way im doing it
    Jan 2011
    I'm using f20 on my Saab engine and it's fine. Mines at stage 2 map and a few other extras so it's running roughly 240-250. You'll have to modify the downpipe to fit around the f20 but that's not hard, chop the flexi out while your at it. Just don't under-engineer your build cos these engine pack some serious weight and torque figures to match. If you don't get that rear mount right you'll have the engine doing a backflip.
    Mar 2011
    i will be making proper strong mounts but i just need to see a corsa chassis leg modified or a rough idea what to cut and how much to cut
    Jan 2011
    What I do is take the head off the b204, bolt the gearbox onto the block and drop the block and gearbox in. Obviosly bolt the gearbox mount up and stick the driveshafts in, loosely of course, just to give you a rough idea where the engine mount and rear mount need to be. Try chocking the engine in place just to get a few rough measurements. You should only have to cut enough out of the chassis arm for the aux belt but then there's still massive amounts of work to do. Dont forget you must use the Saab radiator or have a custom made 1 cos the Saab engines flow the opposite way so your corsa rad will be useless! You'll probably have to stick the battery in the boot too cos the piping will be very tight
    Stevo
    Mar 2011
    my battery is in my boot oready mate,used 535 battery leads to do that,my mate works at east end radiators in glasgow so i can get him to make me a rad up,i like the idea of the head off to make up the mounts, what do you meen by massive amounts of work still to do lol, as youse all know it hassent been done alot in corsas with no pics of any conversions so idealy i want to do it so people can see the way im doing it and some others follow what im doing so any info on this will be much appreciated, i will upload some pics of my corsa soon just dont laugh at my wheels as it was a trackcar and the wheels are flouresant yellow and so is my rollcage
    thanks
    Mar 2011
    Mar 2011
    the wheels now have slicks and the cage wasent painted at this stage when the pic was taken but it stands out to say the least
    Jan 2011
    mate its not just about getting the mounts right! the engine weighs 3 times more than the chassis was designed to take, so youve got some major strengthening to do otherwise if you go above stage 2, the engine will soon be on the deck (attached to the chassis still!) youve got to sort out the power steering pump issue, the wiring, youll have to try and squeeze the intercooler pipes in. its not like dropping a redtop in where you can simply bolt on a set of v pulleys mate its a serious job! im not trying to put you off and im not trying to say your not capable and im sorry if it comes across like i am, but i dont think you realise how much work is involved!
    it will be worth it when its done but i doubt youll do another. and also as said above youll have to chop a big hole out of the bonnet too cos the engine is very tall. as ive already said though mate the most important part of your build (safety wise) is that rear mount so please dont just use the standard mount with spacers like you would a c20xe because it wont last long.
    good luck and keep us posted
    stevo
    Mar 2011
    mate i totaly understand what your saying,i know the engine is heavy,i know i need to do something with power steering pump and i wont be using standard corsa mounts either, everything will be uprated and as best as i can get on my budget,im not planning running alot of power just something nice and differant,ive got a strenthening kit sitting here and tonite i was talking to my fabracator mate with regards to extending the roll cage in to the engine bay,im planning doing it right the first time to save me having to pull the engine out loads of times, i started tonite striping everything out the corsa bay to get the block and box aligned and to get a start on the chassis leg and mounts, i should be adding pics tomorow of my progress but my plan is to do a build thread with everything,well thats the plan anyway,, your help is much valued
    marc
    Regional Co-ordinator nige-p's Avatar
    Jan 2005
    Moreton, Wirral, United
    saab astra mk3
    the bonnet wont need cutting as the engine will just fit , the corsa with the saab engine i know the lad but there is no pictures off the car as he doesnt want to give the secrets away, i know you need to cut nearly all of the scuttle panel out as inlet sit further back on the engine, and im sure he didnt have to cut the chassis leg but dont bet me on that, as stevo said you are best getting the bottom end in with the gearbox in and then seeing how much space you have got to play with or bits you have to remove you should be able to use the corsa rear mount as you are using the f20 box but as said i would advise strengthening the mountings on the car and the mount itself as that mount takes most of the torque strain from the engine
    Mar 2011
    well as i said any help is better than no help but as there is no pics anywere im just goni need to try it and see how i get on,nige i will need to speek to you regarding a loom or a diagram for making one,pm me with prices if you can mate and also for doing my ecu,thanks mate
    Jan 2011
    With regards to the chopping required for the inlet if that is The case you could always try the inlet manifold off of a 9000 as they are a bit shorter. Ive got a spare one for sale if you do decide to go down that route. As there are no pics if you do decide to use the standard rear mount, you really should go over the top with reinforcing it In my opinion. That's is definitely the key point to the build.
    Hope you put some pics up anyway mate! Good luck with it all. Hope it goes well.
    Stevo.
    Mar 2011
    ive got some pics of were ive started cutting the chassis leg,since no one has any pics of one done ive kinda gone in blind but give me a couple of mins and i will upload the pic
    thanks
    Mar 2011
    Mar 2011
    Mar 2011
    Jan 2011
    How is the build going mate?
  26. #25
    West Midlands Regional Coordinator paddy>gsi/turbo's Avatar
    Nov 2004
    birmingham
    astra mk3
    has a corsa saab been built yet?
    seen nige is planning on doing this does it all fit?
