how to use body filler ?
Results 1 to 10 of 10
Thread: how to use body filler ?
    Jun 2010
    aberdeenshire
    escort van :P
    before i spray my van i will have to fill the dents obv, some people have said to fut the filler over primer, then primer the filler.
    some said to use a flap dink on grinder to bare metal it then filler then acid etch primer.
    which is the best way ?
    and what grade of sanding disks should i use with DA sander to sand down the filler ?
    Nov 2004
    Gloucestershire, UK
    Astra GTE 2.0L 8V
    Re: how to use body filler ?
    Filler should go on to bare metal, otherwise you risk the edge showing over time. 80 grit for a rough pass then move up to 180 then 320. Then primer then carefully flat back if neccessary with 400 or 600.
    Oct 2004
    Oban - West Scotland
    Astra G/Nova TB
    as above, onto clean rust free bare metal.
    Use a large flat block to to all the final sanding to get it flat.
    Jun 2010
    aberdeenshire
    escort van :P
    once i have sanded it, is it just a case of checking by eye that its flat ?
    You can use a guide coat, lightly spray over the top, then when you sand it you'll see any low bits as the colour will stay on them.
    Jun 2010
    aberdeenshire
    escort van :P
    ahh, ok. cheers :P
    Dom
    Dom is offline
    MIGClub Member Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    I always went by touch - if you can feel it, you can see it.
    Jun 2007
    Oxfordshire
    Mk1 Astra GTE, BMW 335i
    Put your fingers in the cellophane that comes on a fag packet and run them over!
    Jun 2010
    aberdeenshire
    escort van :P
    Quote Originally Posted by DeadEye View Post
    dose it just make it easier to feel bumps n stuff ?
