may sound stupid but im thinking of making my own show cage ?
Results 1 to 8 of 8
Thread: may sound stupid but im thinking of making my own show cage ?
    Oct 2010
    hello
    basicly i want a show cage in my car (corsa b) but i was thinking of making my own
    has anyone ever done this before
    and obviously it wouldnt make my car any safer but would it make it any more unsafe ?
    i was thinking about getting some thin tubing getting sections bent already then welding them onto straight tubing so i dont have to do loads of measurements
    i dont know if its a stupid idea i just want to know what people think ? and if they know roughly how much it would cost
    any ideas suggestions etc would be appreciated thanks
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Corsa C20LET/Astra coupe
    Re: may sound stupid but im thinking of making my own show cage ?
    It would make it more unsafe if you have a serious crash you run the risk of having it smash you in the head
    Apr 2002
    Southwest
    Like its stolen
    Nasty chav crap, just fit a proper cage with padding on it or dont bother at all.
    And check with your insurers first as most go mental at the mention of a rollcage.
    Feb 2008
    salisbury
    Transit / 2.0 Nova
    A very bad idea... Even if you were (and may well be) a coded welder it still makes no sense atall.
    I work in and around breakers yards and have seen show cages split and torn into lethaly sharpe objects, so even if it didnt knock you out could well impale you. (or worse, your passenger)
    Show cages should be illegal in my opinion.
    Oct 2010
    righto thanks bad idea then , yehhh i dont want to make my car unsafe so i will wait till a proper cage comes about
    thanks for the comments
    Jun 2002
    Wrectum
    Shuvit, e36 track car
    Make it out of plastic lol. Cover it in cage padding, no one will ever know.
    Apr 2002
    Southwest
    Like its stolen
    You can copper paint plastic and get it chromed, if it was made out of thin wall large diameter waste pipe it would look just like the real thing but be so weak if you headbutted it then it wouldnt matter lmao
    Jun 2010
    aberdeenshire
    escort van :P
    i would say, if your a decent welder then just make a proper one.
