Exhaust welding ??
Results 1 to 6 of 6
Thread: Exhaust welding ??
    Mar 2011
    lincoln
    corsa c 1.4 16v 3dr
    Exhaust welding ??
    how easy is it to weld a standard exshaust
    corsa c 1.4 16v 3dr
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    Re: exshaust welding ??
    If there is steel left to weld its piss easy. If its rusted to bits and you want to patch it up then its difficult
    MIGWeb Moderator
    Midlands
    Nowt
    You mean exhaust?
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    There is a difference between text speak and a mistake. Does everything have to be pointed out by the spelling police?
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Corsa C20LET/Astra coupe
    Quote Originally Posted by Frisco View Post
    Well said, we all knew what he meant
    if it's just a small hole then patch it anyway as the chances are as you try to weld it it will disapear, grind what ever it is back to the nearest good metal and work from there
    Mar 2011
    lincoln
    corsa c 1.4 16v 3dr
    Re: Exhaust welding ??
    thank you guys
    corsa c 1.4 16v 3dr
