Hi guys,
with the 6 piece chassis plating kit, I can see where the 2 small rectangle plates with holes in and the 2 large triangular plates go but where do the other 2 plates go?
(rectangle but with a diagonal cut in them?
Thanks
Hi guys,
Thanks
they go from the back of the crossmember to the triangular plates ,
Here:
is that the ends of the rectangle plates with the diagonal cut in them on the rear facing edge? Is the diagonal cut hidden by the large triangular plates?
Thanks for your help.
