what psi do you paint a car at with an air compressor?
Results 1 to 6 of 6
Thread: what psi do you paint a car at with an air compressor?
    May 2011
    Tyne & Wear
    Corsa
    what psi do you paint a car at with a air compressor ?
    Mar 2010
    Exeter, Devon, United Ki
    Mk 3 Astra 1.8 GSI
    Re: what psi do you paint a car at with a air compressor ?
    It depends on the painter and the paint scheme.
    I normally paint between 2.0 2.5 psi, but thats in a spraybooth. If your painting in a dusty enviroment i would recommend turning it down a tad to get less crap in your paint work unless you like polishing lol
    MK3 ASTRA 1.8 GSI C18XE
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    Quote Originally Posted by tommyknocker View Post
    You sure that's not bar?
    I haven't seen my pressure gaugue in around 3 years, it's under about 50 layers of paint, I know It's not a healthy compressor or a high pressure but I can still get good results.
    MIGClub Member the-darkhorse's Avatar
    May 2009
    poole
    cally turbo td05
    Around 2 bar fella at a push 2.2" no more as you are aware its a hvlp spray gun your using
    May 2011
    Tyne & Wear
    Corsa
    thanks
    May 2011
    Tyne & Wear
    Corsa
    Re: what psi do you paint a car at with an air compressor?
    i wanna spray it pearl white stage 3
