rust on corsa b rear suspension mounts help !!!
Results 1 to 8 of 8
Thread: rust on corsa b rear suspension mounts help !!!
    Apr 2011
    barry
    corsa gsi c20let
    hi guys. well iv gone and taken my rear suspension off and as iv done that iv found a shed load of rust . were the top of the suspension spring goes there is rust. on 1 side there looks to have been a patch up on it. is it posible to cut out and reweld new plates there.
    corsa gsi in white. c20let engine. cover car for total vauxhall issue 114
    Mar 2010
    Re: rust on corsa b rear suspension mounts help !!!
    i had this trouble recenly on my car !! it was weird because was only on the ddrivers side. i removed the round plate the springs goes up to then cut out as much rust as i could, treated any remaining rust and then plated the whole rear chassis rail after i fixed the plate the spring sits on by measuring from the passenger side.
    Apr 2011
    barry
    corsa gsi c20let
    U no the plate at the top were the rear spring holds on to. Mine has all come away. Is there ment to be somthing that it holds on to to keep it in place at the top
    Mar 2010
    Yea it welded to the box section in behind mate ur best cuttin itout see wats behind or wats left
    Apr 2011
    barry
    corsa gsi c20let
    Yeh well if i cut the top bit out can i buy a new top mount to weld back in
    Mar 2004
    Nr Exeter, Devon
    Astra GSI 1991
    Quote Originally Posted by meanmatt View Post
    Just have a look at the good side, and make one youself a plate from some nice steel, Its only a rubber mount I think that holds the spring in position
    Apr 2011
    barry
    corsa gsi c20let
    Any chance u can take s pics dude
    Mar 2010
    Just make one
