How do you pull out damage..........?
Results 1 to 12 of 12
Thread: How do you pull out damage..........?
    Dec 2005
    Bedfordshire
    Astra coupe tur
    Question How do you pull out damage..........?
    Someone hit me in the door few weeks back. It wasnt too bad but it pushed 1 of the door hinges in by about 1 inch. The guy admitted to having no insurance and paid me £200 on the spot. Anyway.....
    My question is, how do bodyshops pull this out?
    Could i try myself with a slide hammer? or how much would a bodyshop jig it out for roughly? Would prefferably try repair it myself as i have repaired alot of things in the past. Wouldnt mind giving it a go.
    Sep 2006
    M1 J28
    Re: How do you pull out damage..........?
    Got any pics of the damage to give a better idea?
    May 2003
    Belgium
    '90 opel omega
    For panels:
    either vacuum things (like for carrying windows),
    drilling a hole + screwing through and pulling,
    or welding a stud (or sticking an elektrode to the panel) and pulling.
    All depends on the damage.
    Hinges itself could be more difficult, and not do-able for 200 pounds...
    Painting alone could be worth more.
    Note: the above may or may not be entirely correct.
    I wondered why the frisbee was getting bigger, and then it struck me.
    Jun 2005
    The Isle of Man
    1.3 Chevette L
    Strip the door down and have a look to see what you can get behind it. I'm thinking things like blocks of wood and wedges or a sill jack jammed inside to push it back into shape.
    In my experience a body shop wouldn't bother repairing a door unless it's impossible to find a replacement. Often the labour cost would be more so a new door just gets bolted on. I'm looking at a similar problem now with a Corsa I've just bought - it'll be cheaper to find a second hand wing and door and get them sprayed than pay someone to try and take the bend out, spend hours getting it flat with filler etc. Perhaps this is a possible for you? You might even find a door in a scrapper that's a near enough colour match!
    Dec 2005
    Bedfordshire
    Astra coupe tur
    Thanks for the replies.
    Its not actually the door hinge thats dented in. Ihave a new door. Its where the door hinge bolts to on the car.... That is pushed in. Ive pulled the inner panels off and i can get to the pushed in damage from behind but, ive had a block in behind it and tried to hammer it out without success. It is rock solid.
    I just dont know if a slide hammer will have enough power to pull it out.
    Mar 2010
    is it the hinge brackets on the a pillar????
    Mar 2010
    the pillar itself is pushed in
    Jun 2002
    Wrectum
    Shuvit, e36 track car
    Photo!
    Normally I'd recommend chaining it to a skip and driving off, but that might be overkill in this case lmao
    Mar 2007
    Gwent
    agila v6
    know someone with a 4x4 and a winch? put a bolt through the hinge and pull the hinge out with the winch, if i was closer i'd do it for you with the truck.......
    Project Astra Aero is underway.............
    Dec 2005
    Bedfordshire
    Astra coupe tur
    Quote Originally Posted by elitedriver View Post
    LOL i thought of that. But was thinking a tow rope around my van then yank it out.
    As to the other comments above yes its the pillar pushed in slightly.
    Cant do pics yet as i need to take the door off again and its a 2 man job due to the weight of it.
    MIGClub Member jamied's Avatar
    May 2003
    northampton
    loads of things
    have to ask, did you report the chap to the police for having no insurance?
    also you could try sliding a plate down the rear of the beam and one onto the front to sandwich it and drill hole right the way though both every say 5 inch, put some good nut and bolt in and tighten up (working like a vice) till it flattens and pulls the shape back.
    Dec 2004
    Near Ely
    Astra sri & 320d touring
    Use a good bit of hard wood between the old door and the flange of the pillar. Push the door closed and the wood will be a pivot and could pull the hinge out.
    If that fails, you will need to chain in down and pull it with a pulling systemn no jig needed!
    http://www.migweb.co.uk/forums/projects-restorations/497800-garage.html
