painters - Prepping transit primer?
Results 1 to 5 of 5
Thread: painters - Prepping transit primer?
    Oct 2003
    Glasgow/Oban
    Like it's a hire car
    Whats the best way to prep that black primer panels come in so I can apply a non laquered 2k solid colour topcoat?
    Thanks
    Re: painters - Prepping transit primer?
    Red scotch bright.
    Or 320 paper.
    MIGClub Member the-darkhorse's Avatar
    May 2009
    poole
    cally turbo td05
    as benn says
    Oct 2003
    Glasgow/Oban
    Do I need to take it all off, or just key it?
    Would you use acid etch on it?
    Is rattle can upol acid etch compatible with 2k primer and topcoat?
    Cheers
    May 2009
    poole
    cally turbo td05
    u only have to key it but the smoother u get it the easier it will be for a smoother finish ( i.e no orange peel )
    it depends how good or bad the cathodic primer is in the first place
    u only need etch on bare metal and its compatible with all 2k systems , u only need a dust coat as to speak and where a mask its evil stuff
