mig welder with 50amp lowest setting ?
Results 1 to 4 of 4
Thread: mig welder with 50amp lowest setting ?
    Oct 2010
    hello ive found a mig welder that i want to buy but the lowest amp setting is 50amps ? apparently you need 30amps or somthing for car body work ?
    what sorta work will i not be able to do with a 50amp minimum ?
    i dont know if this post will make sense as i dont know much about welders
    also its gasless
    thanks
    Apr 2010
    Northern Ireland
    cavalier sr1 v6
    Re: mig welder with 50amp lowest setting ?
    what amp is she rated to?
    ye got a link for a look?
    i wouldnt go as far to say youd need 30amps to weld car body work as all welders differ
    Oct 2010
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Corsa C20LET/Astra coupe
    I weld at higher than that but I just trigger weld it (series of tacks laid half over each other) you should never try and do runs on body panels as you'll distort it to death
