i started changing my interior and found this im not sure how to weld it back on
now i have done this
do i do it like this
or like thios or like this how it was orignal spot welded
or is there another method i can use its a bit fiddley, i was thinking weld up the cracks then put back in the original position or hget a plate cut a hole for the hook and weld the hook on this plate. then cut the cracked section out and weld the plate that would be made on so technically them hook would be back in the original position
any advice would be good
cheers
