spraying plastic how
Results 1 to 12 of 12
Thread: spraying plastic how
    Mar 2011
    lincoln
    corsa c 1.4 16v 3dr
    i need help i want to spray my corsa b arches the same colour as the body how do i do it
    Jan 2011
    Saltburn, Cleveland
    Saab 9-3TiD
    Re: spraying plastic how
    I done mine today, first you need to clean them then sand them down using wet and dry sand paper, grit 600 i used. Then apply a few coats of primer (allow about 20-30 mins between coats), then sand again. Then spray on a few coats of your colour (again allowing 20-30 mins between coats, making sure its dry before the next coat), then sand again. Then add a few coats of clear lacquer for your final finish.
    With primer.
    With paint before Lacquer.
    And on the motor.
    Anyone do it differently?
    Mar 2011
    lincoln
    corsa c 1.4 16v 3dr
    thanks m8
    Dec 2003
    london
    corsa c20let
    start off with a 180p work up too 500p or 600p then clean the plastic apply adhesion promoter. leave for how long it says, spray two coats of primer read the data on the back for drying times. then 500p 0r 600p again then two more coats or primer 500p or 600p ready for colour and clear. try not to use halfruds stuff use u pol high 5 primer and grip 8 (adhesion promoter)
    Mar 2011
    lincoln
    corsa c 1.4 16v 3dr
    where do i get them
    Dec 2007
    Nuneaton
    A carbed xe'd reno kangoo
    any paint shop should do them, even halfrauds do sand paper mate
    Vectra B Estate 2.2
    Vectra B Saloon 2.6
    Mar 2011
    lincoln
    corsa c 1.4 16v 3dr
    ive got sand paper i mean the paint
    Dec 2007
    Nuneaton
    same applies mate
    Vectra B Estate 2.2
    Vectra B Saloon 2.6
    Dec 2003
    london
    corsa c20let
    paint factors would be best bet, not sure if halfrauds sales u pol stuff any more, not been in one for years. if you was close i could of got it off my mate has he works for u pol.
    Mar 2011
    lincoln
    corsa c 1.4 16v 3dr
    starting mine tomorrow
    thanks for all your help people
    Jan 2011
    Saltburn, Cleveland
    Saab 9-3TiD
    No probs mate, let us know how you get on.
    Mar 2011
    lincoln
    corsa c 1.4 16v 3dr
    pics coming soon
