Just wondering how difficult and what sort of work is involved to replace a roof on a Corsa B? Would it affect the structural integrity of the shell etc?
As you can see its looking a bit worse for wear.
Remove the roof rails and windscreen, and take off the boot completely, then its a case of drilling out the spot welds all the way around.
Then just weld the new one in? Would you seal it with something?
yes, seal it with body sealant all around the edge and spot weld the new skin in
Cool how do think this sort of job should take?
i'm guessing you mean how long, well you need to remove the headlining and pillar trims inside the car, then remove tailgate, sunroof if it has one and front screen, and then drill all the spot welds out, thats a good few hours work in itself
Yea I meant how long haha
So all in all a good days work to be done on a nice sunny day then,
Cheers guys!
well the roof needs painting once its fitted so 2-3 days tbh
Can you not use another one from a scrapyard or something?
you can but i wouldn't bother
I heard that welding the roof warps it cus of the heat of the welder? how are people getting around that?
Vectra B Estate 2.2
Vectra B Saloon 2.6
spot welds
You won't really be able to use a second hand one, especially on your first go as they kink and generally wreck them selves.
you can mig a roof on, ideally you want to spot weld it on, but as a diy job mig plugs will be fine, you shouldn't have too much problems with heat distortion as theres ridges and corners where your welding so its not like your welding a flat panel.
Here's a better pic of the roof.
Hi
I Know a guy that change the roof, he changes to a sunroof, its easyaer then u think.
Under the black belts, its the solder points, its where u have to drill the spot weld.
