help needed - car spraying prep?
Results 1 to 14 of 14
Thread: help needed - car spraying prep?
    May 2007
    Limerick, Ireland,
    Astra GSi
    hey, just wanted some info in getting a car ready for paint.. i got a price to getting my astra resprayed but the fella said he cud do it cheaper if i prime it.. so wanted to know what sort of things i need to do to get a nice finish from the respray as i was told the prep is more important then anythink else.. do i need to sand the car down to metal? or just ruff up the paint? im going a diffrent colour as the car is red but i wanna go white.. will any primer do? also what grade sand paper would i need to use?
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    Re: help needed - car spraying prep?
    TBH mate if this is the first time doing it I wouldn't risk it. If you dont get the prep and priming perfect you will be throwing money down the toilet by getting it painted.
    Sep 2009
    stoke-on-trent
    c20xe corsa
    Quote Originally Posted by Gsi_joey View Post
    if your doing it you will need to star off with probly 600s wet untill the paint is flat then go over with 1500s wet then 2000s wet have you got a compresser? and can you spray?
    if not i wouldent bother because rattle can paint uses different thinners to normal paint so the base paint will react with the primer. i allways paint my own stuff but when it goes wrong its harder to fix than to just have it done professionaly
    Dec 2003
    london
    corsa c20let
    500 dry the whole car ready for paint. old school way 800 wet. dont need to go bare metal just a good key, then give the car to him to primer it white. dont do it your self unless you have the right set up.
    Banned
    Dec 2010
    liverpool
    i wouldn't prime it yourself, i'm guessing you'd do it with cans which can actually react with proper paint
    also if you don't have a clue how to do the prep them don't bother, 95% of a good paint job is down to the prep, if this isn't done properly then the paint work won't be the best, also if you've done the prep a painter won't guarentee the paintwork
    i'm setting up my own bodyshop at the minute and we don't wet sand anything, its not really needed, 320 grit on a da sander, then 5-600 on a da sander, clean off car, high build prime, depending on the colour the car is and what colour its going determins the colour of the primer, i stock grey primer and just add colour to colour it, once primed it is sanded with 6-800 grit on da and then 1000 grit, then clean off and ready for paint, but all bodyshops have their own procedure
    Sep 2004
    Nottingham M1 J26
    911. Loves: Dirty sluts.
    It's one of those things that you can't be good at without experience.
    Like buttsex.
    May 2007
    Limerick, Ireland,
    Astra GSi
    i have a compresser so i wont be useing cans for the prime.. im just wondering about sanding down the old paint really, what grades to use after each other.. an im thinking of doing the inside of the car aswell as iv it stripd out.
    Banned
    Dec 2010
    liverpool
    again as above, if you have to ask what grades to sand the paint down with then i wouldn't bother, the prep work has to be done properly to get a good finish
    Mar 2010
    Cheshire
    Golf Mk4, AstraVan
    If you are using isolator/barrier (when the paint underneath is dodgy), does this go on before high build primer, and should etch primer be used still on bare bits?
    “Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
    Banned
    Dec 2010
    liverpool
    personally i remove all dodgey paintwork, not worth leaving an risking it messing up the paintjob, i etch all bare metal and then shoot a good few thick coats of high build which can be da'd/blocked
    MIGWeb Moderator
    Midlands
    Nowt
    My advice is this.
    Dont ask on here, but ask the bloke who is painting it for his advice.
    See what he wants
    Oct 2001
    Inverurie
    s3 + nearly a mk3 gsi LET
    what condition is the car in? if its just a colour change you just need to key the surface. the more work required the harsher you have to get with the sand paper (ie if work is required on wing)
    for a colour change you will have to do all door shuts panel gaps etc. the engine bay would be engine out job to get it the same colour. its really not worth it on a mk3 (buy the car in the colour you want it will be cheaper)
    as for priming if you can see any imperfection it will show up. if you feel any imperfection it will show up.
    basically if you are priming it and someone is painting it ask them if they will look it over and if its crap start again
    Wanted: mk3 astra gsi diamond black bits + let bits dave_hay5@hotmail.com
    Banned
    Dec 2010
    liverpool
    old thread mate
    Oct 2001
    Inverurie
    was only looking at page 1 of this folder too
    migs not as busy as it used to be lol
