I need to repair top of my door can sumeone give me some tips or ideas to blend 3 stage pearl which consists of basecoat pearl coat and lacquer thx
its pretty much the same technique as blending clear over base/metallic
Can u do a quick explaination plz mate
have you never blended before?
No mate
well its hard to explain
Dnt worry then
do a google search, i'm sure something will come up
use the ground colour as local as u can to the repair , then once its covered turn ur gun up to 2 bar and give it a couple of drop coats(fast passes over repair and slightly onto surrounding area,do this 3 times going further every time then once all ur primer is covered with ground coat put the pearl in and do same with that until everything is covered. hope this helps as its not easy trying to explain painting on a computer lol
farmers do it with there wellies on !!!
