Liquid polyurethane supplier?
Results 1 to 15 of 15
Thread: Liquid polyurethane supplier?
    Oct 2006
    channel islands
    Anything
    I am trying to find a place in the uk that sell's a 2 part liquid poly urethane.
    I have searched on the web and only places that come up with it in the grade i need is in the usa, if i have to ill get it from there but surely somewhere must sell it in the uk! i hope so as i cant afford to wait for us shipping times.
    Need it in Hardness shore A80
    or anywhere that even may do it ...
    mike
    Feb 2008
    salisbury
    Transit / 2.0 Nova
    Re: Liquid polyurethane supplier?
    Try looking at boat builders / suppliers. or search Marine grade polyurethene. just a thought, They use it to seal all sorts.
    Oct 2006
    channel islands
    Anything
    Quote Originally Posted by astra_mk2sri52k View Post
    Good idea on the marine side of things not thought of that will have another look now thanks. i wanted it to fill my engine mounts with as i have tried using tigerseal ect... and it does'nt really cut it at all lmaolmao
    mike
    Feb 2008
    salisbury
    Transit / 2.0 Nova
    Engine mounts ey.... You want "3M window weld" Thats what i use.
    A simple google search will make your mind up. All the drifting boys swear by it.
    Its sometimes hard to find in single tubes (most are boxes of 10) but keep looking, Cant remember where i got mine from?
    Nov 2008
    hastings
    let nova, let astra gsi
    i used stikaflex on the mounts in my nova let and its worked a treat, there rock solid and it made a huge differance to the way the car drove. done it about a year ago and its all still in there and workin a treat. im gonna do it on my astra let when i fit my f28 aswell. i got mine from a bodyshop supplier called ponswood paints, or try a panel supplier like hadrians, or britcon etc.
    Oct 2006
    channel islands
    Anything
    Quote Originally Posted by eddgsiturbo View Post
    Thanks for your reply's lad's i have used both of these in the past and while they do improve it a lot it is still noway near as hard as would like. they were both around A60ish in strength and i need at least A80 i have found a supplier that sell's it so i will update this when i have recived it and let you both know how it work's in theory it should be mile's better. it is very similar to what they use for solid engine mounts for xe's ect...
    Im only testing it first so ill get back to you on how it works once it arrives
    regards mike
    Feb 2008
    salisbury
    Transit / 2.0 Nova
    Really? Mine are SOLID. They shake the car to bits on idle.
    Oct 2006
    channel islands
    Anything
    like i said they were a lot beter and like you say are pretty solid but under load it did move still, prob more down to the way i drive it im only trying this as someone advised me to try it as they used to work with it, if its poop i will be going back to what you sugested, gotta be worth a go tho already ordered it now so hope it works lol
    Middlesex
    sideways
    If you want your engine not to move, solid mount it, i.e. without rubber.
    Brian Sidebotham.
    Dec 2007
    Nuneaton
    A carbed xe'd reno kangoo
    ya cant have solid mounts, the car would fall to pieces! it would find a weak point in the chassic and crack.
    Vectra B Estate 2.2
    Vectra B Saloon 2.6
    Middlesex
    sideways
    Yes you can. Anything else to say?
    Brian Sidebotham.
    Oct 2006
    channel islands
    Anything
    Quote Originally Posted by Brian_S View Post
    Thanks for your reply brian. As you say you can certianly use solid mount's e.g. weld them up ect... but as it is to be driven on the road a fair bit it's not really the best option for this situation, tho if it was a single seater or hill climb car that is what i would be doing!
    I have found the product i was after just waiting for it to arrive i will let you know if it is any good once i recive it and have it finished as for some people it should be ideal and worthwhile modification if they have no other alternative as it is not only engine mount's can be used for many different uses.
    regards mike
    West Midlands Regional Coordinator paddy>gsi/turbo's Avatar
    Nov 2004
    birmingham
    astra mk3
    windscreen sealant is good easy to get hold off also
    Aug 2002
    Northwest
    SRi-T, Corsa-T
    Middlesex
    sideways
    If you don't want to solid mount for whatever reason, Radio Spares do some pu compounds too. Shore 85 2-pack: Electrolube | Workshop Consumables | Adhesives, Sealants and Tapes | Potting Compounds | Potting Compounds: Electrolube |UR5097RP250G
    Brian Sidebotham.
