I need to weld up my nova bay for conversion, The bay is great but i need to remove the sealant on the seams so i can stich weld them,
What is the best way to remove this sealant or is there any products that gets it off good ?
When not on axle stands, I'm on boost......
wire wheel on a drill. 80 grit flatting papers good also
were in brum you from?
Blow torch and burn it out in the corners as you will never get in them all and as above i also used a angle grinder armed with the 6" knotted wire wheel and a normal 6" wire wheel for the easy to get to area's
Zip wheel is the best
i used a wire wheel on mine
2nd that. knotted wheel on a grinder / blowtorch. Then flatten the seams so it squashes as much out as possible.
