PROBLEMS trying to get PENETRATION
Page 2 of 2 FirstFirst 1 2
Results 26 to 30 of 30
Thread: PROBLEMS trying to get PENETRATION
  1. #26
    Aug 2008
    Perth ecosse
    Red let
    Re: PROBLEMS trying to get PENETRATION
    Thats a good beginer welder site there coo
    Sep 2010
    Quote Originally Posted by bucky View Post
    as said already, clean your metals up more, make sure the earth is solid. also are you pushing or pulling? try changing the angle your doing it and make sure theres no draught in your work area.
    yeah i realised with a few minor adjustments they improve a great deal
    im also lookin for a better weldin mask as the one i got 15quid from machine mart is rubbish, can u recommend any?
    thanks
  4. #28
    Jun 2002
    cardiff
    cally v6 x30xe
    rule one of welding
    preperation is everything
    good prep leads to good welds dont try and weld through dirt
    the weld wont penetrate through it, it wont give a good contact the arc will stray looking for the best contact
    i use a flap wheel to clean all welds before use so im only welding bright shiney metal
    even metal you know is clean needs a flap before welding
    the best method with mig is too push the torch along rather than dragging it
    if your still not getting penetration up the amps and slow down the speed of travel( not wire speed your hand speed)
    onto masks
    cheep masks are ok if your watching someone welding
    but i would suggest getting an automatic mask personallyi would get the best you can afford
    im using the speedglass type by 3m it comes with its own filter system and airflow
    not bad for seconhand prices on the bay either
  5. #29
    Sep 2010
    yeah ive realised that good preperation makes a big difference, i also brought a flap wheel 2day,
    reduced wire speed down a great deal also
    i too will look on ebay
    wjhat u think of this one;
    Item number: 330502387583
    dont the expensive one's ave a bigger window to look out of?
    looks same as ur one??
    i can afford a 300 mask but would rather spend as LITTLE as possible, ive seen some 3m types with filter, plastic surround for 60 quid
    r u sayin its best to go for one with filter system?
  6. #30
    Jun 2002
    cardiff
    cally v6 x30xe
    yep thats the type damn good price aswell
    mine is the x type (large window) ive only got the adflow system installed as i do a lot of welding
    filter system not needed unless you start doing alot of welding just keep area well ventilated(jam that door open)
