Tip to get a good flowing weld
Results 1 to 14 of 14
Thread: Tip to get a good flowing weld
    Mar 2010
    Hi guys i own a mighty mig 150 and im havin trouble getting a nice flowing weld ! I can strike an ark but cant get technique right to get a nice weld can some people give me sum tips plz
    Jan 2005
    hertford
    ph3.5 zafira gsi
    Re: Tip to get a good flowing weld
    are you using gas?
    www.revardagraphics.co.uk
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    What are you welding? panels or something heavier
    Mar 2010
    Yea using co 2 gas and bit of a mix of metal thickness but most of it only 1mm thick !
    Jan 2005
    hertford
    ph3.5 zafira gsi
    How to MIG Weld - Tutorial thats the best advice i can give you without actually showing you in person
    Apr 2007
    grimsby
    mk3 astra gsi track
    dont use c02 for a start. you want a mix of co2, oxygen and argon. or pure argon for stainless and alli. then to start off put wire speed to just past the middle and try on medium thickness first 2-3mm. and dont rush the weld will only be as good as the prep of what you want to weld so clean everything well.
    bertsteiner
    bert motorsport win it or bin it!
    rc
    rc is offline
    MIGClub Member rc's Avatar
    Jan 2007
    Felixstowe, suffolk!
    359.9bhp astra
    Clean metal is defo the key,
    you can get good flowing welds fine from using co2 if your good but it is easier using argon/argoshield.
    Mar 2010
    Thx mate will have to try different gas then!
    Feb 2008
    salisbury
    Transit / 2.0 Nova
    dont try a continuous weld on 1mm steel, probably just burn through, use a sort of pulse, welding about 10mm then stopping for around a second as the heat disperses then continuing. Forms a nice weld
    Apr 2007
    grimsby
    mk3 astra gsi track
    Quote Originally Posted by rc View Post
    no co2 is just the cheap option. better flow from the weld pool and alot less splatter with argon mix. wouldnt bother with c02 i use pure argon in my mig and with my tig plant for stainless and ally. plus you cant use c02 on stainless and ally.
    bertsteiner
    Dec 2008
    Lincoln
    Disco 200TDI, CBR400RR
    Quote Originally Posted by wetshed View Post
    isnt the whole point of the gas shield to exclude all oxygen from the weld to prevent combustion?
    [SIGNATURE] [/SIGNATURE]
    Mar 2010
    great help guys!! ive now got a mix of c02 and argon and i works loads betta totaly different sound to the ark!!!!!
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    Quote Originally Posted by hay_lewis_68 View Post
    It is designed to exclude normal air from the weld because it causes porosity. Some oxygen in it helps to reduce spatter to keep the heat localised.
    Argoshield is a mix of argon, carbon dioxide and oxygen. The mix depends on which type of argoshield you have and that depends on what you are using it on.
    Pure argon is very good but unless you are welding stainless its not really necessary and its stupidly expensive.
    Pub gas is just carbon dioxide and isn't anywhere near as good as argoshield. Most of it has a lot of water vapour in it too which is less than ideal.
    Jun 2002
    cardiff
    cally v6 x30xe
    one good tip to help with mig welding is to make sure your angle of the torch is correct and that you are pushing the torch rather than dragging it
    also make sure your amps are correct if you think your not getting penetration ie weld pooling up in a ball up the amps and reverse if your getting to much blow through reduce the amps and always/always make sure the weld is clean a good grind with a paddle
    and you are using the correct gas right now (argoshield) for mig, pub gas(co2) if your really cheap
    pure argon for tig only as its bloody expensive and an not needed with mig
    but saying that if you want to start welding ally you got to try hellium with argon, man that makes my welds look pretty good
