clear coat
Results 1 to 6 of 6
Thread: clear coat
    Nov 2010
    clear coat
    hi i was reading a post and now cant find it, ive painted metallic cellulose and need to bring it up to a shine. was thinking of celly clearcoat but thread said to ploish, should i t cut first ? or clearcoat bill
    Nov 2004
    Gloucestershire, UK
    Astra GTE 2.0L 8V
    Re: clear coat
    Where did you get the paint from? Metallic is normally meant to have clear on top, but there are some really old paints that didn't have. Unfortunately if you were supposed to put clear on and you left it longer than 24 hours the clear you do eventually put on may not take that well. All you can do is give it a go and hope for the best.
    Nov 2010
    Re: clear coat
    hi thanks got paint from london england and wasnt advised to clearcoat, just want to buff up but dont want to mess it up. paint 2 weeks ago. no problem another couple top coat if need a clear. will ring supplier up. finish very good but needs to shine thanks bill
    Nov 2004
    Gloucestershire, UK
    Astra GTE 2.0L 8V
    Re: clear coat
    Yes I think you need to contact the supplier, 99.9% of metallic sold these days needs clear on top. You are right you can just flat what's there and put more metallic on then your clear in the right time window.
    Nov 2010
    Re: clear coat
    supplier says farcella 10 gently, dont us3e celly clear doesnt last and 2 pack deadly thanks bill
    Dec 2010
    Re: clear coat
    farecla 10... just ebay 'g10 polish' or pop to your local motor factors.it doesnt have to be ferecla, just the grade of polish (the 10 bit)that matters, its just a finish polish.. good luck with it
