Anyone still use cellulose? Unless it the 2 pack is iso free you need full respirator don't you? My mate reckoned as long as you held your breath while spraying you would be all right.
I was thinking of making a temporary booth in a car port and use an HVLP compressor and cellulose.
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
You need a mask no matter what you are painting.
As above, always have a mask on, even when your prepping the filler dust is also harmful
This is a paint mixing stick with all the different ratios on it
so your going to paint base and clearcoat and solid 2k ?
and you dont know what a mixing stick is?
i wanna see pics before , during and after on this one.....! ;-)
im going to try to do it all but not all on the same car
does the lacquer need rubbing down?
yes if u want to get rid of any bits of dirt/runs blocked out ,ul have to leave to dry for at least 24 hours before u block it down if ur not using a proper oven or ul end up tearing the laquer if it isnt 100% dry ,when it s cured use 1200 or 1500 wet and dry on any imperfections taking ur time not too go through especially the edges,use a small bit o fiary liquid on ur fine sand paper to act as a buffer if u want ,once ur happy panel is defect free ul have to polish with a foam headed buffer/polisher using a suitable polishing compound ,i recomend g3 0r g6
u can sleep in ur car but u cant race ur house
where can i get this g3 from?
most car paint factors will do it ,dig out yellow pages find one local
is it just used as a polish?
mainly used to get rid of any flattening marks the wet and dry paper leaves
ahhh i will get some on monday then
what sort of pressure do i set the gun to?
go on ebay and you can buy spray painting dvd's for as little as 99p lol they do have some good info on them .. practice makes perfect
have a look on youtube some good info on there too
