Need to paint some jacking point covers , do I have to sand them or use special primer ?
just give them a light scuffing and prime normally, dont go to heavy or the plastic with fluff.
I normally lightly sand them with wet and dry using wet then etch prime them
You are supposed to use plastic primer. If you haven't got any primer and need to buy some, you may as well buy the correct type.
use adhesion promoter, like u pol grip 4. then primer, paint etc
